[FOTOS] - Vstrume da KTM?
KTM 990 SM T 2009.
Eu gostei!
Eu gostei!
Fonte: http://www.lidermotos.com.br/forum/view ... hp?t=20208Andre Mello escreveu:
Technical Data
Engine
Engine type Twin cylinder, 4-stroke, V 75°
Displacement 999 cc
Bore x stroke 101 x 62.4 mm (3.98 x 2.46")
Performance (homologated) 85 kW @ 9000 rpm
Max. torque 97 Nm @ 7000 rpm
Compression ratio 11.5:1
Starter/Battery E-Starter/12 V 11.2 Ah
Transmission 6 gears, dog clutch engagement
Fuel Mixture Generation Keihin EFI, throttle valve Ø 48 mm
Control 4 V/DOHC
Lubrication Pressure lubrication with 2 pumps
Engine lubrication Motorex, fully synthetic, SAE 10W-50
Primary drive 35:67
Final drive 17:41
Cooling Liquid cooled
Clutch Wet multi-disc clutch, operated hydraulically
Motor Management Keihin EMS
Chassis
Frame Chromium-Molybdenum trellis frame, powder-coated
Subframe Aluminium
Handlebar Aluminium, Ø 28/22 mm (1.10/0.87"), tapered
Front suspension WP USD Ø 48 mm (1.89")
Rear suspension WP mono shock
Suspension travel front/rear 160/180 mm (6.3/7.09")
Front brake 2 x Brembo four piston fixed-caliper, radially bolted, brake disc Ø 305 mm, floating
Rear brake Brembo 2-piston floating caliper, brake disc Ø 240 mm (9.45")
Rims, front/rear Cast aluminium wheels 3.5 x 17"; 5.5 x 17"
Tires, front/rear 120/70 ZR 17"; 180/55 ZR 17"
Chain X-Ring 5/8 x 5/16"
Main silencer Twin stainless-steel silencer with regulated catalytic converters
Steering head angle 65.6°
Trail 109 mm (4.29")
Wheel base 1505 ± 15 mm (59.25 ± 0.95")
Ground clearance (unloaded) 195 mm (7.68")
Seat height 855 mm (33.66")
Tank capacity approx. 19 liters (5.02 gal)/3.7 liters reserve (0.98 gal)
Weight (no fuel) approx. 196 kg (432 lbs)
Nao consigo ver com bons olhos uma big trail com aros 17...
Mas que ela e linda, isso e...
Re: [FOTOS] - Vstrume da KTM?
coisa linda de deus.
Linda, bem mais bonita que a Strom.
R 1200 GS Adventure Rallye
A KTM sempre faz umas motos diferentes, eu gosto pra caramba... alem de serem excelentes motos... sao brutas tb, se o piloto souber aproveitar bem o q a moto tem a lhe oferecer, certeza q a brincadeira esta garantida.
Quando a fruta esta madura, não demora muito para cair.
Eu acho que vai roubar clientela de suas propias motos.
Ja tem a 990SMR, tem a Super Duke e a Adventure. Suficiente para tres tipos de gostos diferentes.
- lchicralla
Eu tenho coragem de ter uma moto dessa....
Não tenho é DINHEIRO...
_________________
XT600 TÉNÉRÉ/89 - 95 a 98
DT200/96 - 98 a 00
XT600E/99 - 00 a 03
CBX750INDY/94 - 02 a 03
INTRUDER LC1500/01 - 05 a 09
CRF230/08 - jun/10 a out/11
DRZ400/08 – Nov/11..
DT200/96 - 98 a 00
XT600E/99 - 00 a 03
Nossa... Conseguiu ficar mais estranha que a propria VStranha...
Naum gostei...
Naum gostei...
- dsrodriguez
- Registrado em: 08 Set 2008, 14:36
Nao eh meu estilo preferido, nem pretendido, mas eh uma belissima moto..
Novidade ... provavelmente os teus "companheiros" também nãoRichard_CBBrasil escreveu:Nossa... Conseguiu ficar mais estranha que a propria VStranha...
Naum gostei...
Atual: MSM
Atual: MSM
Sensacional... Linda demais... Show de bola...
- mantabodyboarder
Essa moto é muito "bruta" pro pessoal de Quebec
Eu achei louca, agressividade total!
Daqui a pouco o OL tb vem falar que não gostou..luigi escreveu:Novidade ... provavelmente os teus "companheiros" também nãoRichard_CBBrasil escreveu:Nossa... Conseguiu ficar mais estranha que a propria VStranha...
Naum gostei...![]()
- Skolaude
- Registrado em: 27 Dez 2007, 09:29
Ta atrasado hein Braniak... lê aí pra cima
You Get What You Give.
Yamaha WR 250F
Yamaha WR 250F
STRADEIRO2006
- Registrado em: 26 Dez 2007, 11:05
Faço minhas as suas palavras!lchicralla escreveu:Eu tenho coragem de ter uma moto dessa....![]()
Editado pela última vez por STRADEIRO2006 em 17 Dez 2008, 16:10, em um total de 1 vez.
Naum gostei...![]()
Novidade, hauihsuaihsauhsuiahsuiaha
ainda to pra ver uma KTM que eu não gosto!!
auhauhahu
auhauhahu
honda biz ks
Honda CRF450R
BMW S1000RR
BMW ///M3 frozen black f80
BMW 528i e39 turbo
Honda CRF450R
BMW S1000RR
BMW 528i e39 turbo
- Henrique Marmota
Eduardo escreveu:Jota escreveu:coisa linda de deus.![]()
aí já eh sacanagem... hauuehuaheuhauhe
Talvez seja por isso que não gostei...hehehhe
Elviro
- Registrado em: 07 Jul 2008, 08:27
Totalmente demais!
